configure neighbor-discovery cache timeout
configure neighbor-discovery cache {vr vr_name} timeout timeout
Description
Configures a timeout value for entries in the neighbor cache.
Syntax Description
vr_name Specifies a VR or VRF.
timeout Specifies a timeout value for neighbor cache entries. The range is 1 to 32767 minutes.
Default
20 minutes.
Usage Guidelines
None.
The following example configures the neighbor cache timeout for 30 minutes:
configure neighbor-discovery cache timeout 30
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document./>
